Horigan
- Grand Rapids, Michigan
Having a very weird issue...
In 5th or 6th gear (sometimes others), cruising around 40mph with RPMs around 1600-2200 and light pressure on the gas pedal, the engine will start to stutter. It goes away if I press harder (will not downshift) or lift off. But it will happen again if I'm being gentle with the accelerator. There are no flashing CEL's or CEL at all, and the car has no other issues. As far as I know, it's been in to the same VW dealer every 10k miles since new. It has also had its DSG service 25k miles ago.
Should I start by replacing the coil packs, spark plugs and wire rail? Could it be the DV? I hope to god it's not the clutch(es), DMF or mechatronic failure. It shifts and runs smooth otherwise.
The only thing I've tried is turning the ignition on and leaving it sit for 3 minutes. Apparently this calibrates the throttle somehow? I have no clue. I've also read that this is normal, but it sure doesn't feel like it.
I don't have access to a Vag-Com cable, but I do have a wifi OBDII adapter and DashCmd app for iOS. I scanned and had no faults and everything looks normal.
