There are two versions, NA & Euro Eibach
NA Eibach are progressive
Euro Eibach are linear
I have this comparison for different euro Eibach springs across VAG A5 Chassis, I've done this by comparing the TUV certificates on the euro site
*All euro Eibach springs are linear
*Max Recommended Kg has nothing to do with the actual spring rate
*The below info means nothing :biggrin: if you cant order springs individually
Code:
Front
Max Recommended Kg Spring Hight in mm Eibach P#
1005kg 249mm 11-15-009-01-VA
1040kg 251mm 11-15-009-02-VA
1010kg 265mm 11-15-007-01-VA
1080kg 270mm 11-15-007-02-VA
1150kg 270mm 11-15-007-03-VA
1155kg 251mm 11-15-007-04-VA
1040kg 264mm 21-15-007-01-VA
1040kg 270mm 21-15-007-02-VA
1050kg 276mm 11-79-004-01-VA
1160kg 295mm 11-85-012-02-VA
1200kg 284mm 11-85-012-03-VA
1060kg 279mm 11-85-012-01-VA
Rear
0770kg 296mm 11-15-001-01-HA
1005kg 301mm 11-15-007-01-HA
1125kg 303mm 11-15-007-04-HA
0985kg 296mm 11-15-007-15-HA
0785kg 267mm 11-15-009-01-HA
0885kg 273mm 11-15-009-02-HA
0930kg 285mm 21-85-014-01-HA
1010kg 288mm 21-15-007-01-HA
1005kg 295mm 21-15-007-03-HA
1130kg 315mm 11-85-012-01-HA
1010kg 291mm 11-85-014-05-HA
1230kg 305mm 11-85-016-10-HA
