JB4 Logging, stacking and Map 6 Discussion
ChrisMk77
Sweden
2018 GTI Performance
Having issues with cruise control every time I clear codes I can’t use my cruise control what do I do to get it working again?
FUD set to 90? Try to get an O2 spacer to work without setting of a CEL so you can turn off the autoclear.
Andrewbens
Modesto
2019 GTi S 6 Speed
FUD set to 90? Try to get an o2 spacer to work without setting of a CEL so you can turn off the autoclear.
What is FUD? Not quit sure.
I have a vibrant spacer set in the medium plug facing down towards the back of the car.
Edit: ohhh ok I see fud is set to 90 what does that do?
Andrewbens
Modesto
2019 GTi S 6 Speed
90 autodeletes codes and kills your cruise control. Set to 0 to get cc back.
oh thank you! Good to know! I thought auto delete was disabled on the newest update
Andrewbens
Modesto
2019 GTi S 6 Speed
Ok cruise control still isn’t working the check engine light has been off a couple of cycles the fua is set to 0 what else could be the problem?
Andrewbens
Modesto
2019 GTi S 6 Speed
ChrisMk77
Sweden
Did some more logging with 45 FOL on map 1. Does anyone know what good map 6 settings would be for me?
MK7.5 GTI DSG
Stock other than JB4
91 Octane
Map 1 log
Looks good try map2, less dense air at your altitude probably means that you can have a higher target than typically for 91.
