DIY for a high-line cluster so you can see what's needed for vag-com changes necessary:
http://forums.vwvortex.com/zerothread?&id=3604801
That procedure is dependant on obtaining the security codes to re-code the immobilizer.
From the
referenced post ...
maloosheck said:
... There is a slight problem with the whole hi-line cluster swap: you need to read the immo PIN from your existing cluster and from the new cluster. The only way I know to do it is to use the VCC. I noted that not all of the clusters allow to read their immo PINs. Maybe it is a matter of a different encrypting algorithm not yet implemented in current version of VCC: VAG K+CAN Commander 1.4. Anyway, if you cannot read your own cluster's PIN, I would not even start this mod....
From what I have read, VAG K+CAN Commander can read the immo pin from some US 2006 BPY ECUs,
but apparently VW responded by changing the ecu coding enough to break VCC's system on later ECUs.
Although nitroscope8 was a bit harsh - his message is not wrong.
At the end of the day, whether you want to innocently update your cluster
or do something illegal -
the procedure is exactly the same.
That is why VW has gone to great lengths to prevent it.
The correct procedure would be to install the new cluster
and then tow it to a dealer to initialize the new cluster
using the VW authorized method.
This will also create a record that will show up on CarFax,
so if someone is trying to scam lease miles, etc they will get burned.
