Timvgti
- Netherlands
Hi guys,
I have the o.e.m. VW Golf V GTI alarm system plus (don't know how it's called in the US, but in The Netherlands it is called a 'factory class 3 alarm' with angle detection, interior sensors, door sensors, towing sensors, etc.)
You arm/disarm/lock/unlock the MKV with the key/remote.
If you open te doors with the key (not using the remote, but put the key in the driver's door lock) and open the door, the car/alarm gives you around 15 seconds to put the key in ignition.
If you do this, the alarm won't activate, because the chip/transponder in the key is read through the ignitionkeylock.
If you don't (within 15 seconds) the alarm goes on.
15 seconds is pretty much time (thieves can open mkv doors with a master key and then deactivate the alarm system with a special tool/laptop through the OBD-port within 15 seconds), so I want to deactivate this delay!!!
I always use the remote, and if the battery in the remote is empty, I have a spare remote and otherwise I don't mind if my own alarm goes on/sounds immediately.
So how to deactivate the stupid delay?
(I have vcds 10.6)
P.s.: My o.e.m. alarm gives a 'chirp' sound, but wish it was louder.
I read that the alarms in US-mkv's is a 'honk' (using the horn). Why???
Gr.
Tim
(I have vcds 10.6)
Gr.
Tim
