Golf MK5 GTI DSG AWD Conversion
farisidrees
Lebanon
Golf 5 GTI
Phase 2:
Engine Bay Work
Today ABS module from AWD car will be installed.
AWD dsg transmission with T-case bolted to engine.
Installing Engine back.
farisidrees
Lebanon
Golf 5 GTI
Interesting DSG cooler plate!
You're not worried that the oil will not warm up quick enough without the standard heat-exchanger?
I had monitored transmission fluid temp with this plate for several cases, cold start, idle, heavy and slow traffic, autoban cruise, and at all above cases it was warm enough. >78 degree
farisidrees
Lebanon
Golf 5 GTI
Finishing Engine bay work
Engine with new Gearbox are back into the car after ABS pump replacement
TypeR_126
Concord, CA
GTI
Out of curiosity, where are your catch can lines going to?
I could be mistaken, but it looks like they're just looping under the intake to the blue anodized can in front of the battery.
farisidrees
Lebanon
Golf 5 GTI
Yes you are mistaken, They are going to the silver plate (PCV plate) at the top of engine (just in front of the ignition coils).
Stranded in Daytona
Wilmington, NC
06 2 door TR GTI
I was asking where those lines are going to from the PCV plate...
I think this guy:
Was right though. I didn't see the catch can on the other side of the intake.
DeWet
Australia
Drive shaft mounts removed from R32 welded and painted
Can you find these bits only from a wrecked R32? How did you measure exactly where they should be welded on?
Not too sure where I will be able to find these mounts as Im not close to a wrecker with European cars to go find these bits.
Can anyone maybe help me get these and post to Australia with paypal payment?
Sent from my SM-N920I using Tapatalk
DeWet
Australia
I manage to get the propshaft mounts and the heat shield from a wrecker in another state.
Last 2 things to sort is to swap out my mk70 abs for a mk60 that will work with the haldex 4 motion controller
