Austin@giac
- Socal
New Product: GIAC Software for MK5 DQ250 DSG Transmission covering 2009
New GIAC Software for DQ250 DSG:
GIAC is proud to announce the release of performance DSG transmission software for the MK5 GTI and GLI (will support ALL Temic DQ250 mechatronic). This software complements GIAC performance engine software and is installed in minutes using regular GIAC flashing tools through the OBDII port. Installation of the GIAC product does not require removal of the DSG computer from the car.This quick upgrade helps to increase requests, shift speeds and limiters in your DSGs mechatronic to ensure you get the most from your modified Volkswagen.
GIAC's two stages of DSG software truly optimize launch control, shift and torque limiter features for the end users performance modifications:
Stage 1: (MSRP: $550.00 USD/$450.00 USD with GIAC Engine Flash)
- Faster, smoother transitions between gears
- Launch control limiter set at 3400 RPM
- Hard rev limiters set at stock limits
- Remapped sport mode "drive program" with improved ability to hold gears and overheating protection
Stage 2: (MSRP: $650.00 USD/$550.00 USD with GIAC Engine Flash)
- Launch control limiter set at 3700 RPM
- Hard rev limiters slightly bumped over stock to be compatible with most aftermarket tunes
- No automatic kick down in manual mode
- Increased torque limits set to over 500 nM
For customization (such as custom shift and rev limiters) and stage 3 software, please email sales@GIACusa.com.
Check out Panda's review of the stage 2 software here:
http://www.golfmk5.com/forums/showthread.php?t=172988
