Caymanjp
- Grand Cayman
- 2008 3DR Golf GTI
Hi everyone. I have a 2008 Golf GTI with about 90000 miles, I started having really bad stuttering as well as a loud chirping sort of noise under medium-heavy load, I am getting a misfire code for cylinder 2 but scanner does show some misfires on other cylinders too, changed plugs and switched out coil packs and didn't seem to make a difference. I am also getting a P2293 "Fuel Pressure Regulator 2 performance" code. Could my HPFP be on the way out it has someone had a similar experience? Cam follower was replaced early this year. Any way I can test my fuel pump or suggestions to find the culprit? It seems to be gradually worsening and effecting low RPM range as well, on cold start today the car was definitely shaking on idle
