Hi All,
Hope everyone is safe and using the time at home to get cars ready for spring track season!
2 years ago I decided to take my K04 2008 setup down at 73,000 miles to do a complete build, including forged motor, refresh the DSG which already had LSD. Wanted around 500whp track car. So the car got the works including replacing just about everything with upgraded or OEM. List below of what the car has. So since completion I have had 2 major issues. First issue was on the first and only 3 laps in the car. Tuner left wrong plugs in car, electrodes melted off. With proper plugs in the car runs fine but two of the pistons have little bits of electrode on top so they need to be replaced.
Second problem is the one that just happened. Car has been sitting and I put in the plugs I mention above. It started right off with a flick of the key despite sitting for almost a year. Drove it around the neighborhood a few times and on the way home, just cruising the driver side axle bolts (all of them) came out and put a hole in the trans case. Needless to say this could have been very bad had it occurred on the back straight at AAA speedway going 130+. While I don't usually believe in signs, I am going to go with all the problems I have had with this as a sign that I should do something else.
So I am first going to see if anyone wants to buy this project from me. Trans case has a big hole in case so it cannot be driven and the motor needs a couple of pistons. Sounds great so far, right.
Firm price and this will be good for 30 days or so is - $10,000
2008 2dr DSG UG 75Kmi
If no bites on purchase of whole car I will start part out in mid March, ugh.
For pictures you can go to my build post - LINK
This offer is for someone who wants to part out or get in really cheap to go big turbo with a little extra money and time to work on it. I am just worn out and too old to want to do this anymore. I am only posting on the MKV forum.
Car is in Southern California
Now for the more attractive part of the offer. There is roughly 20,000 dollars in parts to be sold and that is selling them at used prices without even considering the engine or trans as part of that 20,000. The body and paint are in very nice shape and paint is glossy and soft to the touch. Headliner had just been replaced along with door inserts. New headlights, foglights, grilles, windshield. It is a very good looking car inside and out.
Description of Stuff most of which has less than 200mi.
Engine - FSI - BPY |
Turbozentrum EFR 7163 |
Mahle 9:1 pistons 83mm |
DM - Forged H-beam connecting rods |
Calico Bearings |
Supertech valves, retainers and guides |
Golf R intake camshaft |
Golf R oil pump with balance shafts removed |
Fluidampr |
IE pinned crank pulley |
APR HPFP |
RS4 fuel injectors |
155 FPRV |
CTS LPFP (TTRS) |
Torquebyte PM3 |
Aquamist HFS4 v3.1 Direct inject - 10L reservoir in back hatch - vented to outside |
HPA v2 intake manifold - drilled and threaded runners with aquamist fittings for jets |
PTP firewall blanket |
034 Motorsport Engine and Trans mounts |
034 Motorsport pendulum arm |
INA roller cam follower conversion kit |
APR intercooler |
Custom intake |
Custom DV relocate |
Custom turbo piping |
Red top Coils |
Golf R Map |
BSH Catch Can |
42DD Full TBE with HiFlo 200cell cat (Magnaflow muff will be replace with Burns Quiet muff) |
AWE boost gauge |
Trans - trans has about 10K miles on it since upgrades/refresh |
Unitronic Stage III DSG tune (custom with extra clamping force) |
New OEM clutch kit and seals |
MFactory LSD |
INA Engineering DSG cooling system (cools trans fluid) |
Suspension - 200mi on these parts |
Eibach Multi Pro R1 coilovers |
034 Track Density strut mount |
Epiceurotuning Tubular front control arms |
034 Motorsport swaybar endlinks |
034 Spherical Adjustable Rear control arms |
034 Spherical rear trailing arms |
034 Spherical adjustable rear toe links |
Unibrace set - UB, XB and R |
Eibach Sway bars - solid - 26f 23r |
TyrolSport Deadset subframe kit |
Corner balanced |
Brakes |
Brembo (red) 18Z brakes - 6 piston F - 4 piston R (345/310) |
RS3 Master cylinder & new GTI booster |
Hawk HPS pads F/R - STREET |
G-Loc R16 and R10 F/R - TRACK |
Neuspeed Stainless lines F/R |
Wilwood parking calipers |
Tyrolsport Master Bracket |
RS3 Front brake ducts |
Fabless rear mount kit for pkg brake and Brembo caliper |
Wheels - Tires |
Michelin Sport Cup 2 - 225/40 |
Track Set - Neuspeed RSe5 - 18x8 (+45) - Michelin Sport Cup 2 - 225/40 |
Note - 18z Brembo calipers fit under all these wheels without spacers |
Lighting |
FTP mod (FTP now come on with high beam – very bright) |
FTP bulbs switched to yellow 2500K Noya |
Euroswitch |
Morimoto LED fogs |
Seating |
Recaro Speedseats (recline/black w/red lettering, block fabric) on dual lock sliders |
Schroth 4 point harnesses (red) |
EuroKreations Rear Seat delete kit |
Notes |
When doing the build a number of OEM parts that are not performance related were replaced for new. |
Wheel bearings f/r |
Starter |
Air Cond Compressor and hose |
Throttle Body |
Alternator |
Vacuum tubing and connectors |
Knock sensors |
LPFP controller |
Radiator and coolant hoses / connectors |
Radiator Fans and mount |
Windshield |
Headlights |
All front grills - OEM with vented fogs |
