RSMark5
- Jacksonville NC
I have up for sale my loved CarPC.
Its an Intel D510MO board integrated Intel Atom 1.66 dual core.
Detailed Specifications:
Case Black Box Mobile Extruded Anodized Aluminum Mini ITX Chassis
10" x 9.25" x 3.125"/254mm x 235mm x 80mm
1x 50 x 50 x 10mm fan 6500RPM 32dB for ventilation
Processor:1.66GHz Dual Core Atom D510
Hard drive: 320 GB
1Mb L2 Cache
667Mhz Front Side Bus
Graphics: Intel GMA 3150/NM10 Express (Tigerpoint)
Graphics engine clock: 400MHz
DirectX 9.0 Support
Audio Six channel Intel® High Definition Audio
Composite/RCA Line Outputs
USB 6x USB 2.0
LAN 1x 10/100/1000 Mbps
BIOS Intel BIOS 4mb flash memory
Rear Panel I/O 2x Ps2 for mouse and keyboard
1x VGA
1x 10/100/1000 LAN
6x USB 2.0 ports
3x Audio: Line in, Line out, and Mic in
Monitoring and Management Power Management (Supports S3 standby)
Fan Speed Control
Hard Drive 1x 2.5" IDE or SATA Hard Drive Support
Memory 2Gb 800MHz DDR2
Supports up to 4GB of RAM
M2-ATX Smart Power Supply: Connects directly to the battery,Voltage regulation,Automatic Start-up
The PC is as I left it and as it came out of my car. Its currently running on WinXP professional. It comes with Centrafuse 3 as the front end program with unhacked legit license. It also comes preloaded with Palmer Performance DashCommand.
The screen is a Lilliput 7" EBY701 LCD Touchscreen
Ratio: 15:9 wide TFT screen
Color configuration: RGB stripe
Video system: PAL/NTSC
VGA input (USB interface)
Full function OSD control (Multi-language)
Audio output: Speaker built-in
Video input signal: 1.0Vp-p, composite video
Power input: DC 12V
Power consumption: 9W
With the PC comes the following Peripheral devices.
Wireless keyboard and mouse (the backs are missing some how)
OBDII dongle
2-4 USB hubs
1 15' USB extension
GPS dongle
USB Wifi stick.
I'm also including the Kicker 75.2 amp. This is what I used for audio, the only downside is only being able to fade front to back rather than corner to corner.
Also including a 30gb SSD hard drive. I planed to run the O/S on the SSD for ultra fast boot times.
The screen is prefit to fit any MKV MKVI Passat etc. Just slid it in and plug it in. (see below pics to see custom made) Its a metra dash kit, with a lilliput double din screen conversion.
Also including a radio harness for a MKV (not sure what else it will work on) to pull audio and power off of.
This whole project all together took me a couple weeks to assemble get up and running and fit perfect. I have over $1,000 invested in this set up. I'm selling my beloved Gisela now for $600 + shipping. I really don't want to sell it, but its been sitting in a box too long.
Screenshot of Centrafuse 3 using embeded Dashcommand and GTR style gauges
Open case
Screen being put together.
No scratchs, just dusty and a couple fingerprints from sitting in the box.
The whole set up laid out
Hard drive: 320 GB
1Mb L2 Cache
DirectX 9.0 Support
USB 6x USB 2.0
1x VGA
1x 10/100/1000 LAN
6x USB 2.0 ports
Fan Speed Control
Power input: DC 12V
OBDII dongle
2-4 USB hubs
1 15' USB extension
GPS dongle
USB Wifi stick.
Open case
