Still can't get the lens holder out of the under dash trim :mad0259::iono:.I've tried a flat blade screw driver to try & prise it out but no joy,what the fcuk have i missed please ?.:frown:
On the US version there are two footwell lights.
The drivers side is mounted in a plastic panel covering the bottom of the dash.
I have always dropped that panel (two T20 Torx)
when I wanted to remove that fixture.
The other one is in the bottom of the gove box assembly.
That one practically falls out on its own on mine,
pops out easily with a trim stick.
But if you need access behind,
it it is easy to push the under dash foam to the side under the glove box
and reach in to release the light fixture from behind.
