DylanRWong
- Vancouver, WA
- 2006 VW GTI
Just DIY'd my timing belt and water pump. After the install, the car started up and idled just fine (so I assume the timing is correct?), but I have begun to experience fuel cuts at about 4500rpm.
The engine will also occasionally stall out when I put the car into neutral from freeway speeds.
Edit: Problem solved. The problem was that the silicone coupler for the intake system was attached to the cold air intake, but not the turbo itself. :bonk: Probably was wiggled loose while I was trying to fit the intake piping back onto the coupler after the timing belt job. Thanks for the input everyone!
