Here's an exerpt from vortex posted by Keith:
APR Garrett Honeywell GT2871APR Turbocharger
Turbine Housing
Turbine Clamp
Compressor Housing
Compressor Clamp
APR Ring Adapter
Retaining Clip
CHRA
APR Turbo Support Bracket
APR Wastegate Actuator Assembly
APR Wastegate Actuator Bracket
APR N75 Bracket
Wastegate Acuator Rod and Rodend
APR Turbocharger Stainless Steel Coolant Feed and Drain Lines
APR Turbocharger Stainless Steel Oil Feed and Drain Lines
APR Oil Line Drain Flange (2)
APR Investment Cast Inconel Exhaust Manifold
APR Investment Cast Stainless Steel Exhaust Downturn
APR Stainless Steel 3” Exhaust Downpipe
APR High Pressure FSI Fuel Pump
Hitachi (OEM) Rail Pump
APR FSI Fuel Pump Plunger
APR FSI Fuel Pump Barrel
APR FSI Fuel Pump Spring
APR FSI Fuel Pump Retaining Nut
APR FSI Fuel Pump Spacer
Rail Pump Seal Ring Set
APR High Pressure FSI Fuel Injectors (4)
APR FSI Injectors (4)
Injector Installation Kit
APR FSI Intercooler
Intercooler Core
APR Cast Aluminum End Tanks (2)
APR Intercooler Silicon Outlet Hose
APR Intercooler Silicon Inlet Hose
APR Carbon Fiber Intake
APR Carbon Fiber Intake Tube
APR Silicon Intake Hose
Hi Flow Rechargeable Air Filter
APR Cast Aluminum Mass Air Flow Intake Tube
Honeycomb Air Flow Straightener
APR Silicon Compressor Inlet Hose
APR Electronic Diverter Valve Housing
APR Silicon Compressor Exit Hose
APR Cast Aluminum Pancake Pipe
APR PCV Valve Assembly
APR PCV Check Valve
APR PCV Valve Flange (2)
APR PCV Valve Adapter
NGK Sparkplugs (4)
8 gaskets, 25 hose clamps, vacuum line and 95 pieces of hardware ranging from Inconel Studs to Nordlock Washers and Flexloc Nuts and other associated bolts, nuts, washers and studs.
APR FSI Stage 3 Installation Guide
