Estimated APR Stage 3 1/4 Mile ET
AndorGLI
18 and i'll still take U!
Boca Raton, FL
VW MKV GLI
thats what he told me 11's. yea that car is nice. i don't see why you can't run at least a high 11. did you see frenchy's car, the black MKIV thats for sale whith BT. he runs 11's. 386hp is good for 11's lol
yeah but i think frenchy ran with slicks or drag radials. i know he aleays runs with bf-goodrich g-force
AndorGLI
Boca Raton, FL
VW MKV GLI
AndorGLI
Boca Raton, FL
VW MKV GLI
and the kit is gonna cost $7200 with intercooler.
yeah thats what i think the kits going for but i know the installation cost a shit load. a little more the the RS/S b/c the APR Intercooler is pretty hard to install.
AndorGLI
Boca Raton, FL
VW MKV GLI
also, what components does the apr stage 3 turbo come with? anyone know, like is it a built engine or just fuel rail, injectors.........
CDN_MKV
Wakka Wakka
Vancouver, BC
07 UG GTI
Where did you get that price from? is that the post-introductory pricing?
JJ
AndorGLI
Boca Raton, FL
VW MKV GLI
JJ
i talked to APR guys and i think thats the price they told me as well
CDN_MKV
Wakka Wakka
Vancouver, BC
07 UG GTI
Here's an exerpt from vortex posted by Keith:
APR Garrett Honeywell GT2871APR Turbocharger
Turbine Housing
Turbine Clamp
Compressor Housing
Compressor Clamp
APR Ring Adapter
Retaining Clip
CHRA
APR Turbo Support Bracket
APR Wastegate Actuator Assembly
APR Wastegate Actuator Bracket
APR N75 Bracket
Wastegate Acuator Rod and Rodend
APR Turbocharger Stainless Steel Coolant Feed and Drain Lines
APR Turbocharger Stainless Steel Oil Feed and Drain Lines
APR Oil Line Drain Flange (2)
APR Investment Cast Inconel Exhaust Manifold
APR Investment Cast Stainless Steel Exhaust Downturn
APR Stainless Steel 3” Exhaust Downpipe
APR High Pressure FSI Fuel Pump
Hitachi (OEM) Rail Pump
APR FSI Fuel Pump Plunger
APR FSI Fuel Pump Barrel
APR FSI Fuel Pump Spring
APR FSI Fuel Pump Retaining Nut
APR FSI Fuel Pump Spacer
Rail Pump Seal Ring Set
APR High Pressure FSI Fuel Injectors (4)
APR FSI Injectors (4)
Injector Installation Kit
APR FSI Intercooler
Intercooler Core
APR Cast Aluminum End Tanks (2)
APR Intercooler Silicon Outlet Hose
APR Intercooler Silicon Inlet Hose
APR Carbon Fiber Intake
APR Carbon Fiber Intake Tube
APR Silicon Intake Hose
Hi Flow Rechargeable Air Filter
APR Cast Aluminum Mass Air Flow Intake Tube
Honeycomb Air Flow Straightener
APR Silicon Compressor Inlet Hose
APR Electronic Diverter Valve Housing
APR Silicon Compressor Exit Hose
APR Cast Aluminum Pancake Pipe
APR PCV Valve Assembly
APR PCV Check Valve
APR PCV Valve Flange (2)
APR PCV Valve Adapter
NGK Sparkplugs (4)
8 gaskets, 25 hose clamps, vacuum line and 95 pieces of hardware ranging from Inconel Studs to Nordlock Washers and Flexloc Nuts and other associated bolts, nuts, washers and studs.
APR FSI Stage 3 Installation Guide
CDN_MKV
Wakka Wakka
Vancouver, BC
07 UG GTI
Also posted by Keith today:
The retail price of the complete kit with APR FSI Intercooler and APR FSI Fuel Pump is $7299 with an introductory price of $6569.
The retail price of the kit without either the APR FSI Fuel Pump or APR FSI Intercooler is $6599 with an introductory price of $5939.
The retail price without both the APR FSI Fuel Pump or APR FSI Intercooler is $5999 with an introductory price of $5399
Introductory price is only good until they start shipping though...
JJ
07mkvgti
Rally Car Newbie
Pembroke Pines, Fl
06 GTi
thats a lot of shit. now i see why it's so expensive. but theres a few things that i'll have on that list before the turbo kit so it'll come out cheaper.
AndorGLI
Boca Raton, FL
VW MKV GLI
does the apr stage 3 come with pistons and rods and is it a built motor?
AndorGLI
Boca Raton, FL
VW MKV GLI
nope thats stage 3+. i believe they said that'll be out early 08 so i'm sure we'll be putting down over 400hp with that kit.
o than doesn't the stage 3 produce 350whp and if thats so, how is the stock internals being able to withstand that? and how much do u guys think that the stage3+ is going to cost around???
07mkvgti
Rally Car Newbie
Pembroke Pines, Fl
06 GTi
stage 3 is at 388whp on 109oct. stage 3+ will be over 400(like VF Engineering, but more power). i predict around $10,000 for the entire stage 3+
