Rollback50k
Yeshhhhhhhhh
- NY
Fixed by http://elitemotorsport.net/ check them out.
dont throw parts at the problem until you diagnose what it is. wasting money isnt a good way to learn. did you vag it? what did you come up with? aux fans can stay on even when the car is off. most manufacturers even put a warning label near thew fans to remind tech's/owners about this feature. how do you know if it is running rich? just the smell of fuel could have been coming from somewhere else (esp if you are in a repair shop). scan for codes and see what you come up with. im sure that there are plenty of local peeps that can help you out with vag-com
The car can run without the MAF plugged in because it goes into open loop...which means it stops using input from your sensors (maf, o2, etc.) and uses a base file map that's known to be safe. It reverts to programmed parameters.
When your car is in closed loop, it's using input from the sensors.
Unplugging the MAF is a great way to diagnose if the MAF is bad. Unplug it while the car is running and if your idle gets better, your MAF is BAD. If your idle gets worse, your MAF is GOOD.
Hope that helps :thumbsup:
wow this is some good info, didnt know that. im gonna try this even though i dont suspect its bad just for the hell of it
Unplugging the MAF is a great way to diagnose if the MAF is bad. Unplug it while the car is running and if your idle gets better, your MAF is BAD. If your idle gets worse, your MAF is GOOD.QUOTE]
Yeah, I thought i had posted that in the first post. That was actually the first thing i checked when i ran I had to pull over.
yessir, don't be surprised if you get a CEL. If you do get it for unplugging the Maf, just give it some time and it'll go away on it's own. If it doesn't and/or it bothers you too much, just either uplug your battery and let it sit unplugged for roughly 20 minutes and plug it back. It should be gone, keep in mind if your flashed with Revo(Not sure if other flashes such as APR, Giac etc. also) your most likely going to have to get it flashed again. I've had a few times where I've done those steps and I didn't notice anything as far as having to reflashing it back to stage 2.wow this is some good info, didnt know that. im gonna try this even though i dont suspect its bad just for the hell of it
I don't know if this is true for the 2.0, but on my 1.8t the traction control light will turn on if you unplug the MAF. It will turn itself off after a few minutes of driving once you plug the MAF back in. Just so you don't freak out if it turns on :wink:
That's funny because my traction light came on once my car started to freak out (And I obvi. I have the 2.0)
Bump, hopefully my friend is able to help me out and vag my car after work.:happyanim:
You did, I was just giving more detail on how the car operates without the MAF plugged in.
Have you ever heard of this happening before? I think it's more of a wives tale if I'm not mistaken.
