Here is a DIY for all the R32 and VW onwers out there who need a lil light in the glove box. For some odd reason VW stuck a AUX input in the GB instead of a Light. I would have rather had my AUX in my Arm-rest Console and a light in the Glove Box.
Well here u go!!!!!!!!
Parts List
1. Glove Box Switch- 1K0 947 561
2. Light- 6L0 957 416
3. Black Male Adapter- ?????????
4. Posi Tap- just one
5. Solder Iron and solder
6. 18g Wire-
First thing i did was to remove the Glove box, passenger foot well panel, side panel, and foot well console.
Use this link to remove glove box
http://golfmkv.com/forums/showthread.php?t=135719
Then u need to splice ur wires together so it looks like this.
Then get under the dash on the drive side and find the CECU with the Connecter K and Pin 10. This wire is Blue/Red and will be tapped with a
Black Posi Tap.
Then u need to run this wire to the passenger side where the glove box is.
Once u get it thru u can start to fix the wire where u want it behind the glove box. Remember where u put the wire cause then u will be putting the glove box back in and u dont want to pinch the wire and damage it. I ran the wire along the side of the car panel where the Main Wire bundle is, ran this wire from the top to the bottom by the the foot well ground wirer. This is where u will be grounding the wire and completing the circuit.
Once u run this wire and u got it where u want it, then u need to ground it to the ground place where the factory grounds are.
After that now u can start to put the glove box back in and make sure u dont clip ur wires. Once the glove box is half way in now u want to connect the Rubber hose to the AC for the glove box. DONT for get the connect the Black Male connecter in the glove box switch. Now u can push the glove box in all the way and hope that u dont clip any wires. If not the last thing to do is plug in the glove box light with the black male connecter and it should look like this.Then u will be snapping in the light in the glove box. Also dont for get to snap in the light switch too. This goes in the back of the glove box, there is a where looking cut out and it goes in with the connecter facing up.
Now ur done ENJOY!!!!!!!!!!!
This is a pic of the wire loom that goes from the
Connecter K, Pin 10--Light Switch--Glove Box Light--Foot Well Ground
Thanks Jet Turbo
This Mod has been done b4 but i wanted to make it a lil better and easy to read and under stand. i hope people like it and use it:happyanim:
Thanks Stylist
Parts List
6. 18g Wire-
Black Posi Tap.
Thanks Jet Turbo
Thanks Stylist
