dpham00
Modérateur Emeritus
- Los Angeles, CA
Car runs sluggish,has ESP & EPC light& P0222 code (Angle Sensor (G188):Signal too low
I have a 2007 GTI 2.0T with a chip and while driving, the ESP & EPC lights came on, when i scanned with vag-com, it showed P0222. the car seemed a little sluggish. I cleared the codes with vag-com, but they came right back on. So, i took off the engine cover, and checked the coils, they seemed firmly in place. I looked at the throttle body wiring, it seemed okay, but i took off the harness and reconnected it, then scanned and cleared codes, and the code went away for now, but i'm assuming it will come back sooner or later.
I'm guessing I need the 2018652/2 mentioned here, but I am open to what you guys think:
http://forums.vwvortex.com/showthread.php?4333364
but my question is, how difficult is it to do the repair? My car is out of warranty. Arin in his post above mentioned "optimizing wiring", what exactly is involved, if it's not that difficult, i'd rather do it myself. Even if the dealership covered it under warranty, last time i brought my car into the dealership which claimed to be chip friendly, they basically said they won't do any engine related work without me reflashing it to stock. I called my local chip dealer (I did not buy the chip from them) and they said it'd cost $100 to flash to stock, and $100 to reflash again. They asked why take it to the dealership, take it to them instead. I said it's under warranty (it was at the time - they seemed shocked that a 2007 GTI is still under the 5 year powertrain warranty). I'd rather not take this to an indy either, as they might have a hard time diagnosing it.
Anyone have any suggestions or input?
Scan of codes below:
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH14--- Serial number:
Coding:
Shop #:
VCID:
1 Fault Found:
000546 - Angle Sensor 2 for Throttle (G188): Signal Too Low
P0222 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 48867 km
Time Indication: 0
Date: 2000.00.00
Time: 15:22:25
Freeze Frame:
RPM: 1976 /min
Load: 55.3 %
Speed: 60.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1158
Revision: 04507000 Serial number:
Coding: 0000020
Shop #:
VCID:
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
Shop #:
VCID:
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Coding:
Shop #:
VCID:
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 48867 km
Time Indication: 0
Date: 2000.00.00
Time: 15:22:25
Freeze Frame:
RPM: 1976 /min
Load: 55.3 %
Speed: 60.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Voltage: 13.843 V
Coding: 0000020
Shop #:
VCID:
Revision: 00H11001
Coding: 0021122
Shop #:
VCID:
1 Fault Found:
