GTIRaider
- Sioux Falls, SD
So earlier today I just finish installing my BSH IC with the BSH throttle pipe. I'm just going to give my thoughts on the process and quality over all.
While installing both the IC and throttle pipe I used the directions from BSH, but theses are okay at best. One thing that may be wrong or could be manufactured incorrectly is the welded brackets on the IC.
Per the picture from the directions you two mounting brackets that have two larger holes and two smaller holes. The smaller holes are suppose to be on the top, this is where I ran into the first issue. If you tried to install the IC with the brackets this way it would hit the foam bumper support; there is no way without heavy mods to that support that this will fit. So we turned them upside down so it didn't hit the support. It maybe the directions are wrong or they welded the supports on the IC in the wrong place. Also the sheet metal screws they supplied had one completely the wrong size.
Being that the IC sit's a bit lower than what I feel it should, the front bumper doesn't fit very well so I can no longer secure the front lip. I will need to do some trimming to fit this.
Also on some of the hoses you will need to trim them and some way more than others, this would be great to say so in the directions.
The throttle pipe was overall a pain with no directions given, but not hard to understand how to install just not a fun install overall.
Overall performance: Overall it's what I was looking for. The car runs stronger and spools quicker. I have yet to get into making some changes in the software settings to fine tune it. I'm sure once this is done I will feel even more of difference.
So for anyone looking to go with their product be warned that you may need to do extra work to make it fit, but the payout in the end seem worth it.
