EvoIII
- California
Anymore feedback on the Bilstein B8s in terms of overall performance and comfort for road use.? There was some information about the MKVI version being " better".
I purchased the mkv b8s, why? Becausehardcorerackor.
No seriously they shipped me mkvs instead of mk6s.:thumbdown:
Conpression of bilstein is actually pretty high n h&r sports spring rates r too low for these dampers.. I think ride would be just as good w/ much better handling with race springs.. Ride comfort is mostly dependent on damper stiffness on this setup so race springs probly be a better match with bilstein mkv b8.
On my rss setup w/ 400# front. There was absolutely no suspension travel. Meaning no droop so big dips - u met the ceiling.
Also u want to control body roll via spring rate not through damper.. When using bilsteins n h&r sports it feels like i am using dampers more so than the springs.
I did a bit of reading and there seemed to be a common theme about both. The MKV version was stiff, very stiff. The MKVI version was considered more compliant. I went with the MKVI version and they are much stiffer than stock and much stiffer than the Koni FSD I had been running just prior. For me, they are at the edge of what a good daily driver should feel like, and for me that is perfect. Handling is superb, the ride comfort is generally very good, but when you cross irregularities in the road, passengers will definitely notice where you as a daily driver of the vehicle will not.
I am extremely happy with my suspension setup and the car handles quite nicely even at very high speeds. Bilstein B8 (MK6), Eibach sways, Eibach Sportline springs, WALK and all the other poly bushing available, Tyrol subframe kit and Goodyear F1 225/40/18
And these shocks accommodate the shorter springs perfectly so you get full travel and I don't believe I have ever hit the bump stops. The stance with this setup is just perfect for a daily, you clear just about everything by a millimeter..
I would give them a 10 out of 10 for a daily driver.
Driving impressions?
Did anyone also change their " end links" and what other parts are worth the time and money when replacing shocks/struts and springs?I did a bit of reading and there seemed to be a common theme about both. The MKV version was stiff, very stiff. The MKVI version was considered more compliant. I went with the MKVI version and they are much stiffer than stock and much stiffer than the Koni FSD I had been running just prior. For me, they are at the edge of what a good daily driver should feel like, and for me that is perfect. Handling is superb, the ride comfort is generally very good, but when you cross irregularities in the road, passengers will definitely notice where you as a daily driver of the vehicle will not.
I had Bilstein B8s and H&R Sports on my car.
They bottomed out from time to time, on larger bumps if I was taking them at a higher speed and what-not.
They rode nicely, but I wouldn't get them again. They came with the car, so I had no say really, lol.
That being said, I think my new coilover setup rides nicer than the B8s. Both lowspeed and highspeed, even with them being significantly stiffer.
So what would you recommend? I've also got H&R Sport springs and I was considering MKVI Bilstein Sports...
