Blocko
Rabblerouser
- Vancouver, BC
Is it recommended to go one step colder if you're only stage 1?
Some people do, some people don't.
I'm considered "Stage 1" with GIAC (Also have DV and intake). I run the NGK Iridiums. The stock plugs did fine as well. What I really like about the NGKs is that he car runs smoother, quieter and the revs are a lot cleaner/smoother.
For Stage 2 applications, it's generally recommended to run colder plugs (Iridiums) although like L0UDG mentioned, some people still run the stock plugs with no problem.
I have been using NGK Iridium BKR7EIX and they work nice, i am on my second set, i find that they will last ~20K miles...before i start getting some cold start issues...when i changed my first set out after 20K they were pretty black with soot.....worse then my STOCK BOSCH ones when i switched to the NGKs.
I also thought about trying the PULSTAR ones, and they are now only $24.99/each off the website. I mean I can't see them doing any harm, except on the website the suggest you call them if you have made any modifications to your engine...etc...etc...I've been meaning to call and find out if I need to go with what pops up for the MKV GTI on their website or something different.
Either way, if anyone has tried the PULSTAR let me know...i was thinking of trying it also, since I am due to swap out my NGK in the next 1000miles.
I think the pulstar strategy is seriously flawed. Their commercial hype that claims great benefit assumes the ignition is driven by a 1950 coil with points and condensor or basic electronic switching distributor with primitive "as-is" waveform output.
Waveform shaping occurs in the ignition module these days and it can be tailored or shaped as desired. High speed, high amplitude pulse output is totally feasible and modern coilpacks can easily multiply this waveform without distortion.
Special in-plug circuitry to alter waveform is not helpful or beneficial, IMO. It's just something else to fail.
The mixture either ignites or it doesn't (misfire that can be felt). Combustion energy is not a function of spark energy, so greater horsepower does not result from stronger spark. Once adequate ignition performance is achieved, greater spark energy or magnitude will not provide significant benefit. This is especially true if the car is normally aspirated because the spark is not subject to pressure blowout.
I have one more concern........
This pulse plug will definitely retard timing to some degree, pun intended.
The strategy they use to increase spark magnitude will introduce a delay in the initiation of spark. Since ignition timing is not mechanically adjustable on the M5, this spark forming strategy would seem to have a serious shortcoming. The active knock systems may be able to compensate under most use, but light throttle cruise may see some default delay that could impact efficiency.
I have been APR stage 2 for a while now...After Running Road America, I feel comfortable with the stock plugs even under heavy loads. Not one misfire at RA and I was at Full Throttle for 80% of each lap or so...No issues with knock, pre-ignition, or hesitation (with A-revision coil packs, no less). Putting a new set of stock plugs gapped at 28 in next week from ECS. The plugs still look good with little soot or visible electrode wear.
Just my .02 from a high load situation.
Does anyone know anything about brisk plugs? I've heard good things about them but idk. When the time comes it's neither brisk or the Bosch ir fusions.
