MkV GTI front brake is called "FN3(16)", which disk is 12.3inch(t=25mm), it fits 16" wheel minimum.
MkV R32 is called "FNR-G(17)", 13.6inch(t=30mm), and it 17" wheel minimum.
I've seen the mention of 16" somewhere under ABS in Vag. They tried several codes there but everyone of them was throwing some fault codes. They also say about firmware in ABS not accepting the new brakes or wiring differences (bridge or ground connection) >
T47/14 <> T47/38 = PR-1ZF/1ZM/1ZC (15")
T47/12 <> T47/38 = PR-1LJ/1LL/1ZE/1ZD/1ZP (15" & 16")
T47/14 <> T47/39 = PR-1LK/1LM (17")
Now, I'm not an expert with vag-com and nor an electrician but from what I understand, I should change some pins in the ABS sensor connector !? Even so, I never worked with pins so I don't quite know what T47/12<>T47/39 means (this is the one i should have with the new brakes) !
