I have a 2007 GTI Stage 1 at approx 115,000 kms.
Lately, it's been acting a little funny:
-it has a rough idle, where the revs surge double the normal levels (starts at 800rpm and then surgest to 1600 or so off and on)
-the heads up display is showing me worsening fuel mileage than it used to: would often say I have 500km on a tank at full, now will say 400-450km
-when the air conditioning is on, there is a very loud fan sound that turns on. When I turn off the car, the fan winds down but is still fairly loud. My mechanic said it wasn't an issue but wondering if others have seen this.
Videos:
Fan sound while engine and A/C is on
Fan sound when engine and A/C just turned off
Engine only
The check engine light is on and this was the readout:
Current Fault Log
P0300: Random/Multiple Cylinder Misfire Detected
P0302: Cylinder 2 Misfire Detected
P0304: Cylinder 4 Misfire Detected
Pending Fault Log
P0171: System too Lean (Bank 1)
P0301: Cylinder 1 Misfire Detected
P0303: Cylinder 3 Misfire Detected
P0507: Idle Control System RPM Higher Than Expected
From what I've read on the forum it seems as coils/plugs are a possible fix, as would a PCV fix.
Any suggestions on how to approach this? Should I just replace the plugs and coils or should I be testing a few things first before I do it? Same thing with the PCV...
Thanks for your help!
Videos:
Engine only
Current Fault Log
Pending Fault Log
