Naois
- Waterbury, Connecticut
- 2007 VW GTI
Ahh, good point. I'll stick to OEM for now tho. My second 'C' valve is still working.
This may be a daft question or answer. Depends on which way you look at it
I have not gone in to as much research as noregrets78, not by a long way, but let me ask this question.
The slower reaction of the Forge DV to the OEM DV I think is down to friction of the moving parts in the Forge DV to the OEM DV. If this is the case, why don't we try to reduce that friction by mirror polishing the internal bore of the Forge DV. Just a thought. Please don't flame me!!!!!!!!
The Forge valve has a length of hose that needs to reverse flow before the valve can actuate.
i am a genius :tongue:
It will make maintenance in the end a HELL of a lot easier. Cleaning and re greasing is required at least once a year and the BSH solution being right on top of the motor makes that cake work! The forge you have to jack up the car and remove the valve, undo the lines, redo all of it, and it's not the easiest to get to.
Can we get back on topic please!!!
BSHs is maintenance free..
