clockwise33
New York Giants Fanatic
- NJ
I've decided for now to focus some more on vacuum leaks and today I tried to test the brake booster hoses, valve and brake booster itself with a hand vacuum pump and gauge.
The valve seems fine letting air go to the intake manifold but not back. Hoses have no cracks but what I've found really strange is that the brake booster doesn't hold vacuum at all. Not sure if it's normal or not but I expected it to hold.
My brakes are working correctly but I discovered that if I pump the pedal quickly when the engine is running, the idle starts to bounce and on my boost gauge I see the vacuum raising from 22 to 18 Hg.
Again not sure if all this is normal or not.
I'm doing all this to figure out if I have a small leak at the brake booster that the vacuum pump can overcome and keep the brakes working properly but enough to throw off my fuel trims.
Does your brake pedal become stiff after the car sits over night?
