I've been fighting this code for about 5 weeks, threw new parts at it (MAF, front O2 sensor, G247 fuel rail sensor) and did a smoke test through the intake (no leaks). New valve cover and fuel filter were replaced earlier in December. Cam follower was replaced in October.
I run a K04 with Unitronic tune, intake, downpipe and intercooler, Autotech HPFP, Eurojet DV reroute, IE PCV block-off, Forge DV (swapped it to GFB DV+ now but code came back).
Using VCDS I see Group 32, adaptation idle -0.7% and adaptation partial 21.5%
I've done some logging too:
RPM Timing Angle BTDC
2120 21
2160 21
2160 21
2200 21
2200 20.3
2240 20.3
2280 13.5
2400 6
2480 2.3
2600 -3.8
2720 -8.3
2840 -9
3040 -8.3
3240 -8.3
3360 -6.8
3560 -6
3720 -5.3
3920 -5.3
4080 -5.3
4240 -4.5
4400 -4.5
4600 -3.8
4760 -3.8
4840 -3.8
5040 -3.8
5240 -3
5320 -3
5440 -3
5560 -3
5680 -2.3
5800 -2.3
5920 -1.5
6040 -1.5
Fuel
Rail Pressure (specified) Rail Pressure (actual)
72.3 72.3
73 73
74.2 74.2
74.9 74.2
75.5 75.5
78.1 76.2
87 90.9
95.4 97.3
105 103
108.8 108.8
109.4 109.4
109.4 106.2
109.4 107.5
110.7 108.2
112 110.7
113.9 112.6
115.2 113.9
115.8 117.8
117.1 116.5
117.8 116.5
118.4 118.4
119.7 119.7
122.2 124.2
125.4 124.8
128.6 124.8
129.3 125.4
129.3 128
129.9 131.2
129.9 129.9
129.9 130.6
129.9 131.8
129.9 130.6
129.9 130.6
RPM Group 106 - Field 1 Electric Fuel - Pump 1/2
2000 51.8
2080 52.9
2200 54.1
2320 56.1
2480 58
2640 60.4
2840 62.4
3040 64.7
3320 67.5
3560 69.4
3840 71.4
4040 71.4
4280 73.3
4600 75.7
4720 76.5
4880 76.5
5080 76.5
5240 77.6
5440 78.8
5600 80
RPM MAF
2120 14.17
2160 14.33
2160 14.78
2200 14.81
2200 15.22
2240 30.31
2280 50.36
2400 59.56
2480 75
2600 99.25
2720 126.14
2840 128.89
3040 124.64
3240 119.14
3360 144.44
3560 152.08
3720 167.19
3920 166.53
4080 184.5
4240 188.17
4400 195.75
4600 202.19
4760 203.31
4840 205.19
5040 208.75
5240 213.78
5320 218.56
5440 218.33
5560 221.11
5680 227.56
5800 230.14
5920 230.39
6040 233.36
RPM Boost specified Boost actual N75 (%)
2440 2110 1550 74.5
2560 2120 1950 74.5
2680 2120 2340 74.5
2880 2130 2500 74.5
3040 2120 2400 58.8
3240 2120 2400 59.6
3480 2100 2430 56.9
3680 2070 2410 56.1
3880 2040 2400 56.1
4080 2020 2370 56.1
4240 2010 2350 55.7
4440 1990 2290 54.1
4640 1960 2280 53.7
4880 1940 2270 51.4
5000 1920 2220 51.4
5200 1910 2170 50.2
5360 1910 2150 47.1
5480 1900 2120 46.7
5640 1890 2090 45.5
5760 1880 2060 45.5
Based on all this it seems my problem is with timing angle between 2000-2500rpm. I don't see any LPFP or HPFP issues in the logs myself and like I said above I've replaced MAF, O2, G247 and checked for intake leaks.
Not sure what to try next...
2120 21
2160 21
2160 21
2200 21
2200 20.3
2240 20.3
2280 13.5
2400 6
2480 2.3
2600 -3.8
2720 -8.3
2840 -9
3040 -8.3
3240 -8.3
3360 -6.8
3560 -6
3720 -5.3
3920 -5.3
4080 -5.3
4240 -4.5
4400 -4.5
4600 -3.8
4760 -3.8
4840 -3.8
5040 -3.8
5240 -3
5320 -3
5440 -3
5560 -3
5680 -2.3
5800 -2.3
5920 -1.5
6040 -1.5
Fuel
72.3 72.3
73 73
74.2 74.2
74.9 74.2
75.5 75.5
78.1 76.2
87 90.9
95.4 97.3
105 103
108.8 108.8
109.4 109.4
109.4 106.2
109.4 107.5
110.7 108.2
112 110.7
113.9 112.6
115.2 113.9
115.8 117.8
117.1 116.5
117.8 116.5
118.4 118.4
119.7 119.7
122.2 124.2
125.4 124.8
128.6 124.8
129.3 125.4
129.3 128
129.9 131.2
129.9 129.9
129.9 130.6
129.9 131.8
129.9 130.6
129.9 130.6
2000 51.8
2080 52.9
2200 54.1
2320 56.1
2480 58
2640 60.4
2840 62.4
3040 64.7
3320 67.5
3560 69.4
3840 71.4
4040 71.4
4280 73.3
4600 75.7
4720 76.5
4880 76.5
5080 76.5
5240 77.6
5440 78.8
5600 80
RPM MAF
2120 14.17
2160 14.33
2160 14.78
2200 14.81
2200 15.22
2240 30.31
2280 50.36
2400 59.56
2480 75
2600 99.25
2720 126.14
2840 128.89
3040 124.64
3240 119.14
3360 144.44
3560 152.08
3720 167.19
3920 166.53
4080 184.5
4240 188.17
4400 195.75
4600 202.19
4760 203.31
4840 205.19
5040 208.75
5240 213.78
5320 218.56
5440 218.33
5560 221.11
5680 227.56
5800 230.14
5920 230.39
6040 233.36
2440 2110 1550 74.5
2560 2120 1950 74.5
2680 2120 2340 74.5
2880 2130 2500 74.5
3040 2120 2400 58.8
3240 2120 2400 59.6
3480 2100 2430 56.9
3680 2070 2410 56.1
3880 2040 2400 56.1
4080 2020 2370 56.1
4240 2010 2350 55.7
4440 1990 2290 54.1
4640 1960 2280 53.7
4880 1940 2270 51.4
5000 1920 2220 51.4
5200 1910 2170 50.2
5360 1910 2150 47.1
5480 1900 2120 46.7
5640 1890 2090 45.5
5760 1880 2060 45.5
