Some updates:
I tested the G410 sensor using the method I've found online and the pressure difference between the low side (6.5 bar) and high side (6.4 bar) is 0.1 bar which is within spec. I also have the latest sensor version (K). All this means the sensor is OK.
I've done intake smoke and pressure testing two more times this week, used the brake cleaner method again and I just can't find any leaks.
Yesterday I removed the intake, DV reroute piping, throttle body pipe and checked for cracks. Re-tightened everything back.
The P310B code never came back and it's been a week since. I know that the day before it happened it got really low on gas before I could reach a gas station, maybe the code got triggered then.
I don't think the in-tank pump is the problem, I went through another tank of gas and the code hasn't returned. Plus the fuel pressure on the high side meets the request based on my logs. I assume if the tank pump is bad I would see issues there, correct?
I would hate to spend the money for a new pump and not solve this as I already replaced 3 sensors for nothing.
Meanwhile I'm still driving with a CEL and fuel trim (long) at 22.3% :mad0259:
