darcness
- Grand Blanc MI
- 2008 GTI CW
It just means that you'll have amber running lights. Other then that, everything should function the same.
i'm planning in doing this mod this weekend. if i don't have access to vagcom, will the amber light bulb blink as well (in other words, both outer circle and amber light blink together when i turn on the signal, and both light up when i step on brake)?
i'm still a little confused. if the outer brake light also works as blinker, can't we just disconnect the blinker metal from the outer brake light and connect it only to the added amber bulb?
another question which is a little bit off topic. if i choose to use this amber light as blinker, can i still somehow go for rear fog light?
thanks again!
got it! basically is to change the blinker light from the outer circle to the newly added amber light. i wonder if i only change the byte/bit to 00 in my current stock setup, the outer circle will only be on when i turn the signal.
btw, do u mean the circle on the trunk door is the rear fog light? i would love to connect the brake light function to that circle. that would be perfect setup. i don't know y they have that circle there but with no light. what's the point?
I actually was able to make real amber signals with an amber lense...check it out
That appears to be an OEM US clear lens with an amber color filter, or gel, inserted from the bulb side of the housing. In other words, someone stuck a plastic transparent piece colored amber and secured to the inner portion of the clear lens.
