that is close to impossible to reach!
No it's not, I did it easily enough (albeit forgetting the lower crush washer, causing an oil leak... since resolved ) Took about an hour all told, being careful with everything. Torque spec is 30nM.
I just installed the Defi Racer on mine and I really like it. If you connect one of the wire to the illumination source (aka the solid gray of the light switch harness) then the gauge will dim when lights are ON. However, the gauge will flicker if you turn the dimmer switch lower (the voltage is too low to keep the gauge constant).
