itisagoodname
- Bay Area, CA
- '08 G37S
So its the timing belt? Is it slipping or is it actually rubbing inside the cover?
Hmm, time to try it. 4 bolts for the timing cover?
Well, I tried moving the cover around. It reduced the noise somewhat, but it's not completely gone. I'll mess around with it some more. By any chance did you see how badly it was rubbing or where?
So I just got back from the dealership and the issue was definitely the timing belt cover. Reason I say that is that when they installed the new one--it starting squeaking again and it took them an hour to get it on correctly. Apparently there is not much room for error. The gap between the belt and the notch is less than a half an inch.
Yea is it possible that you can scan the paper work or like give me the part number for the new timing belt cover... since my warranty is over i think i have to order the part myself and install it at my tuner shop...
I had the timing belt replaced by dealer before but it did not fix the problem...
Hey man, chances are the cover just needs to be repositioned.
Anyway, my car is going back to dealer since its doing it again . The guy that repositioned the old one (which worked a full week) wasn't there when I got my new one put in. The "new" tech that put the new one in was a noob and needed another tech to help him put it back in (it took nearly an hour and a half).
I will update you on the part number when I find my paperwork.
