Having issue after installing a used Eurojet Racing CAI...the car is not boosting over 5 to 8 lbs in 3 and 4 gear. Also, noticed that his noise pipe is always popping off by the firewall. Car is on OEM software.
I have replaced the DV value since the car is still on the original DV after almost 75K
Here are the codes I'm getting...
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H43N58NB
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 364DEBD7419380AE71B-8063
2 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 120235 km
Time Indication: 0
Date: 2000.00.00
Time: 19:07:42
Freeze Frame:
RPM: 4384 /min
Load: 100.0 %
Speed: 88.0 km/h
Temperature: 68.0°C
Temperature: 23.0°C
Absolute Pres.: 830.0 mbar
Voltage: 14.224 V
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 120243 km
Time Indication: 0
Date: 2000.00.00
Time: 19:15:11
Freeze Frame:
RPM: 3258 /min
Load: 100.0 %
Speed: 111.0 km/h
Temperature: 78.0°C
Temperature: 25.0°C
Absolute Pres.: 840.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
P1297 was the first code I was getting right after the first CEL come up. P0299 show up after the DV replacement
I was wondering if my turbo is going bad or could it be something else...
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 120235 km
Time Indication: 0
Date: 2000.00.00
Time: 19:07:42
Freeze Frame:
RPM: 4384 /min
Load: 100.0 %
Speed: 88.0 km/h
Temperature: 68.0°C
Temperature: 23.0°C
Voltage: 14.224 V
P1297 - 002 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 120243 km
Time Indication: 0
Date: 2000.00.00
Time: 19:15:11
Freeze Frame:
RPM: 3258 /min
Load: 100.0 %
Speed: 111.0 km/h
Temperature: 78.0°C
Temperature: 25.0°C
Voltage: 13.970 V
