you will get misfires codes as well as lower limit boost exceeded codes of which you can clear with VAG...i would suggest that you align the throttle every now and then....group 060 in VAG....you can update to firmware 3.2 via serial port on wotbox...make sure to read the wotbox settings to see if the clutch and throttle value is correct...
