GTI2007 said:
Not to be picky but the 2.0 TFSI already has an integrated diverter valve on the turbo from the factory. If you buy the Forge BOV you just replace this diverter valve.
No, when you get the Forge SPACER, it spaces the distance the air has to travel through the Diverter Valve. This is how it is able to get the "Whoosh" noise. Think about blowing a whistle, it is almost exactly the same concept. You use the same stock diverter valve when using the spacer.
There is no Blow-off valve for this engine, just a diverter-valve spacer.
I've said this in a couple other posts, but I'll reiterate it here. I had a Forge spacer on my car for about 3 weeks and drove about 1000miles with it. First of all the sound gets really old. It happens every time you decrease throttle at all. Even when you think about letting off the gas it seems to blow off. This may happen just driving normally, it may be when shifting, either way it happens A LOT!!! I decided to take it off because of this reason.
After taking the valve off, I went for a quick drive. The car was noticeably quicker stock. Shifting was smoother too as not as much power was lost engaging the clutch. I was blown away with how much power was lost. I didn't expect any gains in power, but I didn't expect to lose any either.
If you think about it from an engineering standpoint the car is designed to use a diverter valve. This means that some of the unused boost will be returned to the intake, and the car is expecting this to happen at a certain rate depending on boost PSI. When you send some of that boost out into the atmosphere, the car is losing some of the boost that it is expecting to use again. Now I don't fully understand the functions of the cars ECU, but I would think that it would be a little confused when that boost just disapears rather than be returned to the intake. This is why I think the car loses power. It is not getting the same amount of boost as it is supposed to, and the turbo is not constanly spooling at the rate it is supposed to in order to reduce turbo lag.
This is all just my little input since I've owned the product and used it for a good amount of time. I don't have any dyno number to prove, nor do I have any A/F readings. However, my butt dyno tells me that power was being lost. How much power? not much, but enough that once I took the spacer off my car felt faster and smoother.
