Valandil
- South Africa
So bought a VagCom thought it would be a good thing to have. Still looking at the available changes I can make but having a 'Euro' spec model seems to suggest a good number of things are 'on' by default.
However upon doing a scan I came across the following. Any suggestions or input? I did take a look at the RossTech site and they have a number of possibilities but wanted to hear from you guys what tend to be the most likely culprit and solution.
Thanks
Mileage: 40510km-25171mi
3 Faults Found:
012600 - Intake Manifold Runner Control
P3138 - 008 - Regulation Deviation - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 39275 km
Time Indication: 0
Freeze Frame:
RPM: 1401 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 54.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.557 V
012599 - Intake Manifold Runner Control
P3137 - 001 - Basic Setting not Completed - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 40251 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 60.0°C
Voltage: 8.890 V
001602 - Sensor Reference Voltage A: Circuit
P0642 - 002 - Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 40502 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 60.0°C
Voltage: 9.652 V
Readiness: 0000 0000
Thanks
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 39275 km
Time Indication: 0
Freeze Frame:
RPM: 1401 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 54.0°C
Voltage: 11.557 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 40251 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 60.0°C
Voltage: 8.890 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 40502 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 60.0°C
Voltage: 9.652 V
