HYDE16
- Morris County, NJ
FOR SALE -- UNIVERSAL PERFORMANCE IGNITION SYSTEM:
Okada Projects Plasma Lift (Universal) = $250 (retails for $375-$399 new).
Product Description: Plasma LIFT is connecFOR SALE -- UNIVERSAL PERFORMANCE IGNITION SYSTEM:
Product Description: Plasma LIFT is connected at the Power Side of the ignition coil and increases spark voltage, which is especially beneficial for turbo charged engines. When turbo pressure is increased, the engine requires a much higher spark voltage, based on Paschen's Law. If this extra voltage is not delivered, it can cause misfire. Plasma LIFT prevents this misfire. Furthermore, the Plasma Lift is designed so that the voltage adjustment is possible. This feature will give you more freedom to adjust air/fuel ratio and plug gap and performance is increased.
Plasma LIFT works perfectly together with all other Okada Projects Plasma Ignition parts and increases secondary spark voltage and spark current. This extremely important increase in secondary current creates a faster burn for high performance engines. In addition to increasing horsepower and torque, test vehicles have shown a moderate improvement in fuel mileage. The Plasma LIFT is engineered to increase spark effectiveness on modern cars and is 100% compatible with any late model OBD and engine control units.
Install Instructions: http://www.ignitionprojects.com/sites/default/files/PL1000001S_IP.pdf
Product Page: http://www.okadaprojects.com/usa/products_lift.htm
Product Page: http://www.ignitionprojects.com/catalog/plasma-lift
