Trouble downshifting from 3rd gear into 2nd. Anyone else?
Ryanw0
Michigan
2015 Volkswagen gti
Recently it’s been warming up where I’m at and now cooling back down to 30°s-40°. I’ve noticed recently it’s very hard to downshift into 2nd gear from 3rd. We had a nice day out and I was cruising and rev matched and went to shift to 2nd and it grinded out. Even before this happened it’s been having trouble and I’m wondering if anyone else has had the same issue before? Possible trans service or could it be the synchro? Every other gear is smooth as butter and no trouble at all up or down shifting.
2015 gti SE 6 speed manual
TrueGTI
CT
I suggest using the clutch with rev match to save the gears. See if that does something different. Try everything ! Good luck bud
Ryanw0
Michigan
2015 Volkswagen gti
What do you mean by use the clutch? Should I be double clutching? I always fully press it in while shifting and when it grinded the other day I had it fully pushed in. But will do, thank you!
TimCv1
CO
GTI mk 7, Tiguan MQB
If you double-clutch to rev-match you're bringing everything to the right revs together, single-clutching you are not. I double-clutch for downshifts but single/just let the revs drop for up as a compromise because double-clutch upshifts it's a really quick thump-thump, not that it's hard to get right, just more that it's annoying.
That said I don't think this affects your issue. How close is your rev-matching? If it's right on and it's still not going into 2nd clean, it's obviously not the synchro as it wouldn't come into play. How is the 1-2 UPshift?
Daks
Toronto
GTI PP
You probably need to line up your cables, they are under the intake box.
Ryanw0
Michigan
2015 Volkswagen gti
1-2 up shift is normal and no trouble at all going into second, it’s only when I try to downshift from 3rd-2nd. I’ll definitely try double clutching though. Thanks for your input! Appreciate it
jannickz
new york
golf
Grinding while shifting, especially isolated to one gear, is a common sign of transmission trouble in manual cars. While there could be other causes, worn synchronizers (synchros) are a strong possibility on your 2015 GTI SE.
TimCv1
CO
I have my doubts on this since he said 1-2 upshift is just fine - worn synchros are most common on this (often abused, or at least heavily loaded - edit, er, rushed really - from a stop) shift and are very obvious.
TimCv1
CO
It's the cables.
Sounds like you know what's going on here - so basically I don't really know how this part works, I suppose it's cables work in tension so it's different cables going down vs up so it's those cables that are not aligned right or whatnot?
Ryanw0
Michigan
2015 Volkswagen gti
Appreciate everyone’s input on the situation, it’s been getting a bit better where I can actually get it into second from third downshift, but there’s still been a few times it won’t. I’ll be doing the trans fluid tmrw along with the cable realignment so hopefully I’ll have an answer then. Thank you again to everyone who’s helped!
