I think this might be useful info for someone. Mod's put this where you will.
If you are looking to change tire size with your stock 17's, this might be useful info.
Tire diameter = Wheel diameter (inches) + width (mm) *25.4*Sidewall ratio/50\\
*Formatting wont work for some reason, just read across 225 should be under width, Sidewall should be 45, wheel size should be 17, tier diameter 25.0, speed error n/a and the last number is fender gap.So just follow it down. Or see attachment.
Width Sidewall Wheel Size Tire Diameter Spd Error Fender Gap
Original 225 45 17 25.0 n/a 0.0
Lower 225 40 17 24.1 3.7 0.4
Lowest 225 35 17 23.2 7.6 0.9
+1 235 40 17 24.4 2.3 0.3
