I bought my cheap hail damaged golf 3 years ago I started looking for performance improvement options.
When I found a person selling off GTI parts on gumtree I jumped at the opportunity to get the suspension and HID headlights.
Since he also had the cylinder head and ecu I increased the scope of my dream.
Because of IMMO I first tried to read and flash the chip on the ECU and after frying 2 ECUs I kinda gave up.
Looking at replacing my cluster with the newer white one I managed to get Marin from the US to also IMMO code up a GTI ecu so that my existing ECU, new cluster and the GTI ECU would work with the new key transponders he provided.
Removing valves from the cylinder head I noticed all of them were bent so I had to replace valves and skim head before adding new valve stem seals
Waiting for the opportune moment to change the engine was a pain but had to be done as this is my daily driver.
3 days of annual leave would do it, I thought, but since removing the old cylinder head, manifolds and exhaust with ALL the lambda probes took a while and then after getting all the way to the charge pipe that connects to the throttle it showed me that I would need to replace the oil filter housing too
Another order from VW and another week of wait but then finally managed to get all the engine work done and car reassembled.
Engine turned over but wont start which get me to look at error codes.
Too many to mention which pointed to wiring issues and the had to draw up a comparison between my BLX wiring and the new BWA wiring of the T94 ECU connector( the 60 pin connector was wiring from the cylinder head so it was not my old wiring so didnt need anything to change).
One 12v 87a wire that shows on BLX and BWA diagram is missing from my wiring harness so left it open for now.
Another week of re-pinning T94 while scanning and sorting out errors it also lead me to the T14a connector where I had to do more changes.
I think I covered everything(except the missing earth pin2 which I ordered from DigiKey now to add when it arrives)
