DanSan
meerkat
- LI, NY & PA
- 06' TR GTI/09 UG GTI
we all get those low vacuum cold starts, loud ones too if you have CBFA but mine have been getting worse. normally it hovers around 10Hg until it settles out at 20 but the past few days and it climbs up the boost gauge closer to 0 each time. hell, today i was convinced she was going to hit 0 and go into boost somehow. the other day it even felt like it was back firing and would pop or hick-up.
only way im able to stop it is basically rev the motor which brings it higher into vacuum and it calms down completely and quiets down significantly. i do that for a solid 30 seconds or so to avoid this annoying cold start.
all spark plugs and coilpacks were replaced like less than 2k miles ago. i did put in a neuspeed motor mount insert which has definitely increased the issue (dont recommend, it makes the car vibrate like hell at slow speeds).
any ideas? motor mount is definitely coming out so they should help but they were still a little rough before that. came out of nowhere too
