Trust me.. if u see that d2 in person, u would think that it looks different than what u see in the picture..
those spokes are really curved so much (each end of the curve are at same offset)so there is a huge gap between the caliper and the wheel spoke.. and the spoke come out nearly flat to the lip.
it will never give you the deep staggered look.
If u want that looking wheel then go with work meister s1 which is the original version of D2. work wheels are all custom made (offset, diameter, width, also the disc.).
you would get very tight brake clearance ( i had less than 5mm) and those spoke curves back into the inside the rim, will give better aggressive look.
if meister is too pricey, then go with ssr proffessor sp1.
if u goo with rota d2, you would be happy for first 3~4 months and you are gonna list them on classified.
here are some pictures of the meister s1 I had before.
and SSR professor sp1 can be found at tirerack.com
