I know how much you all revile FM transmitters here, but the one I have actually sounds reasonable, especially for $10. It works with any FM radio that I've tried EXCEPT the one I need it for - the RCD 500 in my 2007 Mk5 Golf GTi.
What happens is that if I tune in to it (e.g. on 88MHz), for a few seconds it sounds perfect, but then it all turns bad/static like it's not getting a proper signal. However, if I simply change to another frequency on the RCD 500 and go back to the original (e.g. 88.1 and back to 88 MHz) it will once again be good for a few seconds, then go bad again.
It clearly seems to be some kind of problem/function with the RCD 500 as the transmitter works with any other radio. What could be causing this? What can be done about it?
