Emissions test is 2 part in CA. Visual, where they look to see that everything emissions related is still in place. Readiness, is second part, through odb2 the reports back the status of emissions related sensors. With software like VAG-Com you can check readiness youself.
The biggest difficulty would be the visual test. The most obvious would be the aftermarket downpipe part of your turbo back exhaust. Best to put stock downpipe and cat back on. Your PCV valve should be fresh and in place. Your air intake would need to be stock or one that is CARB certified. I believe Neuspeed (which I have) is the go to for CA guys as they have a CARB certified model.
I have heard a lot of talk about CA now checking for tunes but I have not seen one post on the various boards I follow saying that someone in California actually had a smog station check for a tune. You should be able to pass readiness part of test with your tune in place. I had a stage 3+ MKV and I would just put my stock downpipe on and pass. Once you put your stuff back on as I have described you will need to drive it under varying conditions for a hundred miles or so for everything to reset. With a laptop and VagCom software you can simulate that driving by running a routine and at the end of the 15min or so routine it will report back on readiness and show any errors you might have. I highly recommend this diagnostic tool if you don't already have one.
Notes -A catch can can be left in place It is not illegal assuming you have not vented it to atmosphere.
- Also I did go in with a tuned vehicle in Nov 2021 and passed but have not done so in 2022.
- You can run your current tune with a stock downpipe just fine for normal driving.
- MPI would be a possible visual failure as well since car did not come with it even though it is oem. I say possible because emissions folks may not know what it is. If you want to run gobs of E85 there is one shop producing injectors and modified harness to go into the stock location that will give you the flow you need. (Mabotech I believe)/ That way you will still look stock.
You cannot force readiness, everything actually has to be working. Forcing or faking it is illegal, just ask VW/Audi.
The readout from the software looks like this.
