well the install was pretty easy up until I had to go in and remove the pipe from the firewall, then all hell broke loose...I never did get the rain tray off because when I tried lifting on it i was just too chicken and felt i was gonna break it, so instead i somehow managed to separate the hose from the speaker box by removing the clamp attaching it and just left the speaker box disconnected in there...i was originally planning on skipping that step but then realised the 90-degree elbow leading back to the noise pipe interfered with it ...i did manage to remove the wipers but they were a pain...and then to top it all off I had a socket w/ a 3/8 to 1/4 adapter attached that i dropped, when i accidentally hit my hand on something, over the coolant reservoir that i never did find :help: ...i searched and even had the wife come down to help me look for like an hour...in the end i just checked to make sure it hadn't fallen into the belt and started the car up.
.....anyways, on to the questions...I noted that the MAF sensor is positioned a little farther towards the drivers side than with my pflo before it was cut...it kinda put a bit more stretch on the wiring harness, is this normal? Second, I checked all my connections but I just don't really hear any DV blowoff sound (unless it's really subtle)...though my intake still makes that stupid "goose squeal" sound...i installed the V-twin and hooked it up to the forge valve...no more woosh sound when i let off the gas, is this normal????? I don't have my boost gauge installed yet (will do that tomorrow), so for the moment I have the second port capped off with the little cap that comes with the kit....also, on an unrelated note, I picked up a used EJ PCV kit but had a question as to which way the arrow on the valve body should point (toward the radiator or towards the cabin??) TIA guys!
