Not likely going to find a fix or something to prolong addressing it inside a bottle. But what can one bottle hurt....it shouldn't hurt anything and there's a chance it will prolong the issue, right? I say try it.
Good luck.
You can address how the oil is getting into the combustion chamber, PCV system is the main suspect.
High mileage blend oils usually have a higher flash point if its worn rings.
