2008 Rabbit 4 door is lighting up the TPMS light on sudden maneuvers only. No fault stored. It also lit up the brake wear indicator light, but only temporarily (no fault stored).
Is there a place I can easily access a wiring diagram to try and see if there is a common denominator somewhere (ie bad ground, rodent damage) that would cause both those intermittent symptoms?
thanks in advance!
thanks in advance!
