@golfdave - followed your advice and cleared the codes using VCDS. The codes that have reappeared are:
01-Engine -- Status: Malfunction 0010
1 Fault Found:
17158 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:58
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 19 °C
Intake air temperature: 19 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.880 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
03-ABS Brakes -- Status: Malfunction 0010
2 Faults Found:
0288 - Steering angle sensor
B1168 07 [137] - Mechanical Failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Date: 2020.09.08
Time: 09:41:22
16390 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:31
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
2 Faults Found:
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
(Aware of this fault)
549652 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
10-Park/Steer Assist -- Status: Malfunction 0010
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
13-Auto Dist. Reg -- Status: Malfunction 0010
4 Faults Found:
1056 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
Control Module temperature: 23 °C
Voltage terminal 15: 11.7 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:21
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
1 Fault Found :
65650 - Turn Signal in Exterior Mirror
B11FD 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 182
Mileage: 219090 km
Date: 2020.09.08
Time: 09:41:20
5F-Information Electr. -- Status: OK 0000
Any help would be appreciated.
