CMARNOLD78
- DC
How is your Clubsport exhaust going? How is the sound, pops/crackles etc?
Yes, some of my friends with MK7's had mentioned that my OEM MK7.5 exhaust is slightly louder, by how much I don't really know.
Any truth to this? First time I’m hearing that the Mk7.5 exhaust is louder than a Mk7.
I bought a magnaflow cat back from a local dude who was trading in for a new Rabbit. He said the cat back didn’t translate from old to new.
There’s zero difference between mk7 & 7.5 OEM exhaust other than the muffler and tips.
There’s also a thread around here somewhere comparing AWE track to OEM 7.5 CBE. The owner felt there wasn’t a difference in volume between the two paired with his downpipe
So stock vs stock, Mk7 vs Mk7.5 exhaust should sound exactly the same? I was under the same impression until I kept reading comments here and there stating otherwise (e.g. the screenshot I posted above with a comment by a performance muffler shop)
I am Baun Performance, GTI Jake is my screen name.
Anyway, the super restrictive OEM downpipe probably hides the difference if you compare mk7 vs 7.5 completely stock.
The muffler (which includes the tips) is definitely both different internal and externally between the mk7 and 7.5. Adding an aftermarket downpipe highlights this difference because the volume is drastically increased (no more super restrictive OEM downpipe to aid the muffler in keeping things quite).
Also, keep in mind that my first reply to this thread was BEFORE I had personal experience with modding mk7.5, thus I only knew about tip spacing at that time.
Ah gotcha. Thanks for the clarification.
I guess my question when distilled to the basics is what’s louder with stock DP only? Or roughly the same with stock DP?
I’m considering getting a Clubsport S Muffler which I’ve heard on a Mk7 and think it’s perfect loudness (wouldn’t want to go louder). If the Mk7.5 is louder than the Mk7, not sure I want to pair the CSS Muffler with the 7.5
I feel like you’re not understanding anything I’ve said.
The ONLY difference is the muffler (which, yes includes the tips), so if you’re changing the muffler to a CSS it’s exactly the same sound regardless of mk7 or 7.5 as you’ve changed the part that makes them different in the first place
Lol my apologies. It finally clicked and makes sense now. Having discussion of how the DP affects the sound had me including a variable in the sound equation that doesn’t matter if the axle back portion of the exhaust is all I’m changing.
Thanks for the clarification again [emoji1303]
No problem, glad I could help
If you’d ever consider a downpipe in the future I’d suggest the downpipe and midpipe first rather than CSS. This is what all three sound like together (it’s rowdy)
https://youtu.be/M_0z5LEsc9I
