mattttt
Hey guys, per the usual, I’m starting a build thread to keep track of my progress with the GTI. I’ve had the car for over a year and have been modding it pretty slowly, but I’m starting to accelerate the pace so I’ll be documenting it here. Most of my mods will continue to be OEM+ and performance-oriented, but K04 (or Stage 3) and air ride are likely inevitabilities. My intention is to build a daily drivable, canyon- and track-friendly show car.
I'll be continually editing this post as I mod the car and adding detailed pictures as I go. My next post down shows its progression to this point since I bought it as a bone stock, babied CPO last year. All work and following modifications have been performed myself unless otherwise noted.
As of summer 2017:
Stock
2011 VW GTI 2.0 TSI (CBFA)
2-door
6 MT
Candy White
Sunroof Package
RCD-510
Detroits
Engine Modifications
APR Stage 2 v2.4 (High Output) ECU upgrade with Launch Limiter & No-Lift Shift options (updated at Emich VW @ 62,341 miles)
APR Carbonio Stage 1 & 2 Carbon Fiber Cold Air Intake
APR Oil Catch Can (installed 6/8/17 @ 62,500 miles)
Billy Boat 3" Stainless Steel Turboback Exhaust (catless)
OEM R8 Coil Packs
OEM Black Coolant Cap
Go Fast Bits DV+
NGK Platinum Spark Plugs
Motul 8100 X-clean 5W40 oil
Soundaktor Deleted (Removed)
Secondary Air Intake Breather Filter Deleted
Windshield Washer Fluid Neck Deleted
Color Matched Engine Cover (Candy White & Gloss Black)
Removed Hood Liner
Transmission/Clutch Modifications
TT-RS RSR Clutch Kit w/ ClutchNet Disk (installed by AU Tuning in Huntington Beach, CA)
Dieselgeek Sigma 6 Short Shifter
034 Motorsports Billet Aluminum Dogbone Mount Insert
TyrolSport Solid Shifter Bracket Bushings
Burger Motorsports Short Throw Clutch Stop
TWM Spooky "Hybrid" Shift Knob
Suspension
AccuAir e-Level Management with Black Touchpad
AccuAir 5 Gallon Tank (powdercoated white)
Air Lift Performance Front Struts/Bags
Air Lift Performance Double Bellow Rear Bags
Koni Yellow Rear Sport Shocks
Viair 400C Dual Compressor Kit
SMC Auto Drain Water Trap
Bag Riders Tank Drain Kit
3/8" Air Line
Neuspeed 25mm Rear Anti-Sway Bar
Removed Front Sway Bar
Frame Notch (done at Empire Fabrication in Simi Valley, CA)
Cut off strut tower caps/hats
Wheels/Tires/Brakes
SSR Professor SP1 three piece wheels, fully polished lips with Cognac Copper powdercoated faces, 17x9/17x10 (refinished, relipped & rebarralled by threepiece.us)
TyrolSport Stainless Braided Brake Lines (Front & Rear)
TyrolSport Brake Caliper Stiffening Kit
Motul DOT 5.1 Brake Fluid
Exterior Modifications
Shaved Hood
Shaved Hatch
Shaved Front Bumper (deleted sidemarkers, headlight washers & tow hook cap)
Shaved Rear Bumper (deleted reflectors)
Color Matched Lower Front Valence
OEM Front Lip Spoiler
OEM LED Bi-Xenon Headlight retrofit
OEM European Golf R Tinted LED Taillights with Rear Fog
OEM LED License Plate Lights
OEM European Blind Spot (Aspherical) Mirrors
ECS Badgeless GTD Grille
Hella Optilux Extreme Yellow Fog Light Bulbs
Pulled & Rolled Fenders (done by Tony "eurocabi")
Deleted rear wiper (using 1" nylon hole plug)
Interior Modifications
OEM Highline CECM
OEM LED Interior Lighting Kit
OEM Dash Cubby
OEM European Cup Holder
OEM Bottle Opener (Black)
OEM Euro Switch
OEM Brushed Aluminum Glovebox Handle
OEM Monster Mats
OEM First Aid Kit
OEM Sun Shade
APR Steering Wheel Insert
GTI Seat Lever Trim (Red)
Double Apex USB Charger
Removed Airbag Warning Stickers
Rear seat & cargo cover deleted
VAGCOM
Disabled Door Chime
Disabled Horn for Lock Confirmation
Disabled Rear Wiper
Disabled Seatbelt Warning
Disabled TPMS
Electronic Differential Lock (XDS) Strength set to 1
Enabled DRL Turn On/Off in MFI
Enabled Fogs with High Beams
Gauge Cluster Staging (Gauge Sweep)
LED DRL brightness set to 70%
ROW Lighting Configuration
Steering Wheel Push-to-Talk Button as Mute
Windows Up/Down with Key Fob
Removed
OEM Base Carrier Bars with Snowboard Attachment
Dieselgeek Panzer Skid Plate
Kill All Wipers Flush Rear Wiper Delete Kit
OEM Audi A8 58870 Ronal wheels (19x9 et33)
Accelera Phi XL tires (215/35/19)
Continental ExtremeContact DW tires (225/40ZR18)
Slam Specialties SS-5 Double Bellow Rear Bags
IDF Tubular Rear Lower Control Arms (powdercoated white)
ST Coilovers (installed by Temple City Auto Repair)
OEM Bottle Opener (Metal)
OEM European GTD Grill
OEM European Short Shifter
42DD Shifter Bushings
APR Boost Tap
VWVenson Black Washer Cap
Color Matched Side Markers from john@FTC5
Modshack Low Profile Engine Bay Trim
NewSouth Performance RedLine Boost Gague w/ VentPod
3M Color Stable 35% Window Tint
deAutoKey LED Interior Set
deAutoKey LED License Plate Kit
Hoen Endurance Fog Lights
DIY Hatch Pop
Klii Motorwerkes Rear Badge Inlay
Klii Steering Wheel Badge Inlay
Color Matched Rear VW Badge
Future Plans
Braille B129 Lightweight Battery
OEM AFS retrofit
OEM Golf R Side Skirts
OEM Edition 35 Front Bumper Cover
OEM Porsche 911 oil cap
P3Cars VIDI Vent Gauge
BFI Stage 1 Motor Mount
BFI Stage 1 Trans Mount
Neuspeed FMIC
APR K04
APR Valve Spring system
Wavetrac LSD
Euro Sport Rear X-brace
Recaro Sportster CS Seats
Porsche Cayenne front & rear brake conversion
Engine bay wire tuck (with deleted rain tray)
I have a history with mini trucks but I’ve always been obsessed with Volkswagens. This is actually the first VW I’ve ever been able to really build the way I want to, but I’ve owned a few:
2003 Passat Wagon GLS 1.8T, Auto, Reflex Silver (lost every picture I ever took of this car, unfortunately)
2006 Jetta 2.5, Auto, Campanella White
2008 Eos Komfort 2.0T, DSG, Candy White
As of summer 2017:
Stock
2-door
6 MT
Candy White
Sunroof Package
RCD-510
Detroits
OEM R8 Coil Packs
Go Fast Bits DV+
Removed Hood Liner
Suspension
3/8" Air Line
Wheels/Tires/Brakes
Shaved Hood
Shaved Hatch
OEM Highline CECM
OEM Dash Cubby
OEM Euro Switch
OEM Monster Mats
OEM First Aid Kit
OEM Sun Shade
VAGCOM
Disabled Door Chime
Disabled Rear Wiper
Disabled TPMS
Removed
APR Boost Tap
DIY Hatch Pop
Future Plans
OEM AFS retrofit
Neuspeed FMIC
APR K04
Wavetrac LSD
