Pspminez
- Portsmouth va
Ok so here is the long story...
I had a coolant leak and a misfire. so i replaced the leaking coolant flange https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/cylinder-head-cooling-flange/06j121132e/
and replaced the coil packs and plugs...car wouldnt start...one of the plugs was incorrectly pre gapped....fixed gap had a mean tick....tick went away now its missing again i get multiple misfire codes that usually start with a p2015 and a cylinder 2 misfire and yesterday my exhaust feel out at the muffler by it self and looking into the pipe as far as i could see was glowing red hot and my coolant was steaming...what could be the problems
had these codes this morning with the following freeze data (p2015 & cylinder 2 misfire) seems the p2015 code is always there as soon as i clear
DTCFRZF 90302
FUELSYS1 OL-DRIVE
FUELSYS2 N/A
LOAD_PCT(%) 41.6
ETC(F) 124
SHRTFT1(%) 17.2
LONGFT1(%) 0.0
RPM(/MIN) 4407
VSS(MPH) 55
SPARKADV(DEGREE) 37
IAT(F) 32
MAF(1B/MIN) 6.885
TP(%) 27.8
AIR_STAT OFF
RUNTM(SEC) 562
FRP(PSI) 2010.2
EVAP_PCT(%) 20.4
BARO(inHg) 29.5
VPWR(V) 14.112
LOAD_ABS(%) 69.8
EQ_RAT 0.999
TP_R(%) 18.0
AAT(F) 32
TP_B(%) 28.2
APP_D(%) 41.6
APP_E(%) 41.6
TAC_PCT(%) 23.5
any help would be appreciated motor is TSI 2.0 all stock
DTCFRZF 90302
FUELSYS1 OL-DRIVE
FUELSYS2 N/A
LOAD_PCT(%) 41.6
ETC(F) 124
SHRTFT1(%) 17.2
LONGFT1(%) 0.0
RPM(/MIN) 4407
VSS(MPH) 55
SPARKADV(DEGREE) 37
IAT(F) 32
MAF(1B/MIN) 6.885
TP(%) 27.8
AIR_STAT OFF
RUNTM(SEC) 562
FRP(PSI) 2010.2
EVAP_PCT(%) 20.4
BARO(inHg) 29.5
VPWR(V) 14.112
LOAD_ABS(%) 69.8
EQ_RAT 0.999
TP_R(%) 18.0
AAT(F) 32
TP_B(%) 28.2
APP_D(%) 41.6
APP_E(%) 41.6
TAC_PCT(%) 23.5
