GorData
I have done this before, it was a PITA
U will need a Huge set of Balls and a set of 12 point torx bits.
1. Take out the seats, Unscrew the 4 bolts and unplug Wire harness
2. Turn seat on it side and take off the plastic bits. The roller knob for the back rest.
then take off the up/down lever, which slides off.
3. Unplug all the Wire harness under seat
4. Once u take the plastic bits on the sides of the seat u will see the 12 torx screws.
5. take these off to disconnect the top to the bottom.
6. Make sure to disconnect all the wire harness under seat
If u get this far then u are good enough to finish the DIY.........LOL
Taking the seats apart requires a skill level of 15 out of 1-10!!!!!!!!!!!!
I do not work for VW and im not liable for ur or any body fuck ups, BUT i will help u as much as possible.....
Good luck
