Opened the garage door today and discovered a small pool of fluid on the floor beneath the rear swing arm... Doesn't look good does it.
Took it out for a quick drive and the back right knocks / clunks on compression. Happened when I backed it off the drive (slowly) and then also over bumps etc... Doesn't sound good does it.
Strangely there doesn't seem to be anything wrong when you push down on the back end (eg boot lip). The suspension compresses, rises & settles correctly.
Anyway, looks like it's shot and the original suspension's going back in. The fronts are on their way out as well I think as the front end takes a while to settle over bumps. The Eibach/FSD's have been on my car for 8k & previous owner's for 25k. It's been awesome.
Does anyone know much about the FSD's and if they can be repaired?
Otherwise I'll re-fit the OEM suspension.
Link to DIY (which contains links to 3 other DIY's).
http://forums.vwvortex.com/zerothread?id=3012010
The fronts are pretty involved. The rears look easy. Might do the rears myself & get a prof to do the fronts in due course.
I mean a professional mechanic, not a professor; I'm not sure he/she'd have the right tools or knowledge...
Cheers,
Tom.
Cheers,
Tom.
